Aller au contenu principal
Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement, Children/Adult Expiratory Filter: étape 1, image 1 de 1
    • Do not begin process while patient is connected. Alarm will sound
    • If necessary, remove the expiratory limb (item 4) of the patient circuit from the exhalation filter.
  2. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: étape 2, image 1 de 1
    • Raise the exhalation filter latch to unlock (item 3).
  3. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: étape 3, image 1 de 1
    • Open the exhalation filter door (item 4).
    • Remove the existing filter. Dispose of properly as per institution’s guidelines on disposing hazardous waste.
  4. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: étape 5, image 1 de 1
    • Ensure filter is properly attached to ventilator
    • Only use filters designed for Puritan Bennett 980 Series Ventilator
    • Insert the new filter by sliding the filter along the tracks in the door. Ensure the from patient port (item 6) aligns with the cutout in the door and points away from the ventilator.
    • Note: The condensate vial (item 5) is removable for discarding accumulated liquid. Turn this vial clockwise to remove. Turn this vial counterclockwise to install.
  5. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: étape 6, image 1 de 1
    • Close the exhalation filter door (item 4).
  6. Puritan Bennett 980 Ventilator Children/Adult Expiratory Filter Replacement: étape 7, image 1 de 1
    • Lower the exhalation filter latch to secure the filter (item 3).
Ligne d'arrivée
Silvia Calinov
Membre depuis le 04/08/20
175 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S11-G14, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S11-G14, Paton Spring 2020
CPSU-PATON-S20S11G14
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 34
Total : 1,315
