Introduction
The Pyle Astro’s screen is comprised of three layers, the external touch panel, the capacitive touch screen overlay, and the tablet’s LCD. Use this guide to replace your tablet’s LCD.
Ce dont vous avez besoin
Using the plastic opening tool, work your way along the edge of the tablet.
Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
Place the front display assembly facing front side down to expose the inside.
De-solder the two wires (see two red arrows in image) that connect the PCB to the LCD panel.
Using a plastic card, gently remove the adhesive that holds the battery in place and separate the battery from the LCD panel.
Install the new LCD panel and solder all the connections back into place.
