Aller au contenu principal
Pyrus PY21S03211 Display Screen Replacement
Ce dont vous avez besoin
  1. Pyrus PY21S03211 Display Screen Replacement, Display Screen: étape 1, image 1 de 3 Pyrus PY21S03211 Display Screen Replacement, Display Screen: étape 1, image 2 de 3 Pyrus PY21S03211 Display Screen Replacement, Display Screen: étape 1, image 3 de 3
    • Find the tab at the bottom covering the battery compartment.
    • Pull back the tab to reveal the battery compartment.
  2. Pyrus PY21S03211 Display Screen Replacement: étape 2, image 1 de 1
    • To remove the battery from the device, pull back the tab holding it in place and then remove the battery.
  3. Pyrus PY21S03211 Display Screen Replacement: étape 3, image 1 de 2 Pyrus PY21S03211 Display Screen Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Open up the display screen.
    • Remove the tab covering the battery compartment using a pair of tweezers.
  4. Pyrus PY21S03211 Display Screen Replacement: étape 4, image 1 de 2 Pyrus PY21S03211 Display Screen Replacement: étape 4, image 2 de 2
    • Use a #00 screwdriver to remove all six 4 mm screws from the side of the device.
  5. Pyrus PY21S03211 Display Screen Replacement: étape 5, image 1 de 2 Pyrus PY21S03211 Display Screen Replacement: étape 5, image 2 de 2
    • To remove the side face of the device, you can use a plastic pick to gently pry it off. Be careful while doing so to avoid potential device damage.
  6. Pyrus PY21S03211 Display Screen Replacement: étape 6, image 1 de 1
    • Carefully open the side face. Keep the side face close to the body of the device to avoid pulling on the white wires.
  7. Pyrus PY21S03211 Display Screen Replacement: étape 7, image 1 de 2 Pyrus PY21S03211 Display Screen Replacement: étape 7, image 2 de 2
    • To remove the side face completely, locate the big white connector.
    • Lift the grey lip using tweezers. Then, carefully take out the white connector.
  8. Pyrus PY21S03211 Display Screen Replacement: étape 8, image 1 de 3 Pyrus PY21S03211 Display Screen Replacement: étape 8, image 2 de 3 Pyrus PY21S03211 Display Screen Replacement: étape 8, image 3 de 3
    • Set the device down with the screen facing towards you.
    • Remove the four 4mm silver screws from the back of the side face.
  9. Pyrus PY21S03211 Display Screen Replacement: étape 9, image 1 de 2 Pyrus PY21S03211 Display Screen Replacement: étape 9, image 2 de 2
    • Use tweezers to remove the small shiny black plastic corner piece from the side.
  10. Pyrus PY21S03211 Display Screen Replacement: étape 10, image 1 de 3 Pyrus PY21S03211 Display Screen Replacement: étape 10, image 2 de 3 Pyrus PY21S03211 Display Screen Replacement: étape 10, image 3 de 3
    • Twist the screen to the side to reveal two black 4mm screws.
    • Remove screws from both sides of the screen.
  11. Pyrus PY21S03211 Display Screen Replacement: étape 11, image 1 de 2 Pyrus PY21S03211 Display Screen Replacement: étape 11, image 2 de 2
    • Use a plastic pick to pry off the backside of the screen.
  12. Pyrus PY21S03211 Display Screen Replacement: étape 12, image 1 de 2 Pyrus PY21S03211 Display Screen Replacement: étape 12, image 2 de 2
    • Use tweezers to open the gray lip of the large white connector and carefully remove it.
  13. Pyrus PY21S03211 Display Screen Replacement: étape 13, image 1 de 1
    • Find two 4mm silver screws at the base of the screen and remove them.
  14. Pyrus PY21S03211 Display Screen Replacement: étape 14, image 1 de 1
    • To remove the gold transparent connector, gently flip open the grey lip using tweezers.
  15. Pyrus PY21S03211 Display Screen Replacement: étape 15, image 1 de 1
    • Locate the two 4mm black screw on top of the display screen and remove them.
  16. Pyrus PY21S03211 Display Screen Replacement: étape 16, image 1 de 2 Pyrus PY21S03211 Display Screen Replacement: étape 16, image 2 de 2
    • Remove green board carefully.
  17. Pyrus PY21S03211 Display Screen Replacement: étape 17, image 1 de 3 Pyrus PY21S03211 Display Screen Replacement: étape 17, image 2 de 3 Pyrus PY21S03211 Display Screen Replacement: étape 17, image 3 de 3
    • Gently remove the white display screen with your hands.
  18. Pyrus PY21S03211 Display Screen Replacement: étape 18, image 1 de 1
    • Carefully insert the replacement screen.
Danielle Hadaway
Membre depuis le 03/31/16
255 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 328
