Outils
Pièces
Start with removing the three screws to open the case. After removing the screws pull/push the case to the backside to remove it.
  • Start with removing the three screws to open the case. After removing the screws pull/push the case to the backside to remove it.
Ajouter un commentaire
Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed.
  • Now you can remove the power supply unit. This requires 5 more screws on the back and two inside the case to be removed.
  • Remove the remaining two screws on the back side. Two more can be found on the bottom and one on the bottom corner left and right. Noch you can careful remove the back of the UX-500P.
  • Now you can remove the final four screws that attaches the 120mm fan to the back of the UX500-P.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Chris Klinger
Membre depuis le 07/05/2016
33 Réputation
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 21
