Aller au contenu principal
QSEW QS-1201 Needle Replacement
Ce dont vous avez besoin
  1. QSEW QS-1201 Needle Replacement, Needle: étape 1, image 1 de 3 QSEW QS-1201 Needle Replacement, Needle: étape 1, image 2 de 3 QSEW QS-1201 Needle Replacement, Needle: étape 1, image 3 de 3
    • Power off your machine and unplug it from the outlet.
    • This will prevent accidental activation and injury, even for experts!
  2. QSEW QS-1201 Needle Replacement: étape 2, image 1 de 2 QSEW QS-1201 Needle Replacement: étape 2, image 2 de 2
    • Have a close look at the difference between the broken needle ( left ) and the brand-new needle ( right ).
  3. QSEW QS-1201 Needle Replacement: étape 3, image 1 de 3 QSEW QS-1201 Needle Replacement: étape 3, image 2 de 3 QSEW QS-1201 Needle Replacement: étape 3, image 3 de 3
    • Locate the needle holder with the broken needle.
  4. QSEW QS-1201 Needle Replacement: étape 4, image 1 de 3 QSEW QS-1201 Needle Replacement: étape 4, image 2 de 3 QSEW QS-1201 Needle Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    J'achète
  5. QSEW QS-1201 Needle Replacement: étape 5, image 1 de 3 QSEW QS-1201 Needle Replacement: étape 5, image 2 de 3 QSEW QS-1201 Needle Replacement: étape 5, image 3 de 3
    • Gently secure the needle with the needle nose pliers.
    • With a tight grip, pull down to remove the needle.
  6. QSEW QS-1201 Needle Replacement: étape 6, image 1 de 3 QSEW QS-1201 Needle Replacement: étape 6, image 2 de 3 QSEW QS-1201 Needle Replacement: étape 6, image 3 de 3
    • Discard the broken needle in a safe place.
    • By doing so, you ensure that no one gets injured when dealing with the trash.
    • Afterward, use the needle nose pliers to insert the new needle into the needle holder securely.
  7. QSEW QS-1201 Needle Replacement: étape 7, image 1 de 3 QSEW QS-1201 Needle Replacement: étape 7, image 2 de 3 QSEW QS-1201 Needle Replacement: étape 7, image 3 de 3
    • Use the 3 mm Flathead screwdriver to secure the screw, without over-tightening.
  8. QSEW QS-1201 Needle Replacement: étape 8, image 1 de 3 QSEW QS-1201 Needle Replacement: étape 8, image 2 de 3 QSEW QS-1201 Needle Replacement: étape 8, image 3 de 3
    • Move the needle using the pliers in a circular motion from left to right to verify it moves freely without hitting any surrounding components.
    • You're all set to use your embroidery machine!
Reema
Membre depuis le 09/10/23
157 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-28, O'Regan Fall 2023 Membre de l'équipe York University, Team 1-28, O'Regan Fall 2023
YORK-O'REGAN-F23S1G28
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 12
Total : 180
