Aller au contenu principal
Qanba Crystal Joystick and Buttons Replacement
Ce dont vous avez besoin
  1. Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: étape 1, image 1 de 3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: étape 1, image 2 de 3 Qanba Crystal Joystick and Buttons Replacement, Button, Joystick and Artwork: étape 1, image 3 de 3
    • Use the Phillips #1 screwdriver to remove the eight 20 mm screws.
    • Remove the metal plate to gain access to the internals of the device.
  2. Qanba Crystal Joystick and Buttons Replacement: étape 2, image 1 de 3 Qanba Crystal Joystick and Buttons Replacement: étape 2, image 2 de 3 Qanba Crystal Joystick and Buttons Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Taking a picture or marking cables with masking tape is advised as it will help with the reassembly process.
    • Each button has three cables, unplug these from each one.
    • The joystick has two cables, unplug both of these.
    • The use of ESD safe tweezers may assist with unplugging the cables.
  3. Qanba Crystal Joystick and Buttons Replacement: étape 3, image 1 de 3 Qanba Crystal Joystick and Buttons Replacement: étape 3, image 2 de 3 Qanba Crystal Joystick and Buttons Replacement: étape 3, image 3 de 3
    • Use the Phillips #1 screwdriver to remove the four 10 mm screws.
    • Use a flathead screwdriver to hold the screw in place.
    • Twist off the ball top of the joystick while holding the screw in place with a screwdriver.
    • Remove the joystick and all of it's components.
  4. Qanba Crystal Joystick and Buttons Replacement: étape 4, image 1 de 1
    • Press in the tabs on the top and bottom of the buttons to remove them.
    • The outline of the buttons are sharp, do exercise caution with the removal of the buttons.
  5. Qanba Crystal Joystick and Buttons Replacement: étape 5, image 1 de 3 Qanba Crystal Joystick and Buttons Replacement: étape 5, image 2 de 3 Qanba Crystal Joystick and Buttons Replacement: étape 5, image 3 de 3
    • Flip the controller over.
    • Peel the six shiny stickers and their epoxy glue off of the controller.
    • Remove the six newly revealed Phillips screws.
    • Remove the acrylic panel.
Kevin Vu
Membre depuis le 06/29/21
121 Réputation
1 tutoriel rédigé
Équipe
York University, Team S2-G28, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S2-G28, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G28
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 22
30 derniers jours : 112
Total : 2,038
