Introduction
Need to know how to replace the motherboard of your Quantum Axis A23? This guide will help you accomplish that.
Ce dont vous avez besoin
Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
Remove all three screws holding down the motherboard, using the Phillips #00 Precision Screwdriver and slot in the Phillips Head PH #0.
Take the the new motherboard and screw it in with the screws used on the previous motherboard, starting with the top right and bottom left corners.
Screw on the top left corner last
Snap the rear case back on to finish this repair.
