Aller au contenu principal
Quiksilver The Fifty50 Circuit Board Replacement
Ce dont vous avez besoin
  1. Quiksilver The Fifty50 Circuit Board Replacement, Strap: étape 1, image 1 de 2 Quiksilver The Fifty50 Circuit Board Replacement, Strap: étape 1, image 2 de 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Circuit Board Replacement: étape 2, image 1 de 2 Quiksilver The Fifty50 Circuit Board Replacement: étape 2, image 2 de 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Circuit Board Replacement, Back Panel: étape 3, image 1 de 2 Quiksilver The Fifty50 Circuit Board Replacement, Back Panel: étape 3, image 2 de 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Circuit Board Replacement: étape 4, image 1 de 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Circuit Board Replacement, Analog Battery: étape 5, image 1 de 2 Quiksilver The Fifty50 Circuit Board Replacement, Analog Battery: étape 5, image 2 de 2
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Circuit Board Replacement: étape 6, image 1 de 3 Quiksilver The Fifty50 Circuit Board Replacement: étape 6, image 2 de 3 Quiksilver The Fifty50 Circuit Board Replacement: étape 6, image 3 de 3
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Circuit Board Replacement: étape 7, image 1 de 3 Quiksilver The Fifty50 Circuit Board Replacement: étape 7, image 2 de 3 Quiksilver The Fifty50 Circuit Board Replacement: étape 7, image 3 de 3
    • Remove the large circular Analog battery.
  8. Quiksilver The Fifty50 Circuit Board Replacement, Circuit Board: étape 8, image 1 de 2 Quiksilver The Fifty50 Circuit Board Replacement, Circuit Board: étape 8, image 2 de 2
    • Using the Phillips #00 screwdriver, remove the two 1 mm screws holding the circuit board to the device.
  9. Quiksilver The Fifty50 Circuit Board Replacement: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Remove the green circular chip using a pair of tweezers.
Sue Giske
Membre depuis le 07/16/19
622 Réputation
5 tutoriels rédigés
Équipe
UW Tacoma, Team S1-G4, Liner Summer 2019 Membre de l'équipe UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 13
Total : 222
