Introduction
This replacement guide will teach someone how to successfully remove the circuit board from their Quiksilver The Fifty50 sports watch. Before getting started make sure to grab the tools necessary and at least skim the instructions once to understand what it will look like while you are removing the circuit board, that way there will be no surprises as you go through the steps.
Ce dont vous avez besoin
Place the watch (face down) on a solid surface.
Carefully use the screwdriver and push in one side of the strap.
Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
Using the Phillips #00 screwdriver, remove the two 1 mm screws holding the circuit board to the device.
