Aller au contenu principal
RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement
Ce dont vous avez besoin
  1. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: étape 1, image 1 de 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: étape 1, image 2 de 3 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Backplate: étape 1, image 3 de 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 2, image 1 de 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 3, image 1 de 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 4, image 1 de 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 4, image 2 de 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Battery: étape 5, image 1 de 1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 6, image 1 de 1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 7, image 1 de 1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 8, image 1 de 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 8, image 2 de 2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 9, image 1 de 2 RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 9, image 2 de 2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
  10. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Antenna: étape 10, image 1 de 1
    • Identify the grey wire on the right side of the device.
  11. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 11, image 1 de 1
    • Remove the orange ribbon cable over the wire.
  12. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 12, image 1 de 1
    • Remove the antenna using a soldering iron.
  13. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement, Motherboard: étape 13, image 1 de 1
    • Remove the blue and black wire from the top of the motherboard.
  14. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 14, image 1 de 1
    • Remove the screws from the motherboard.
  15. RCA 10 Viking Pro RCT6K03W13 Motherboard Replacement: étape 15, image 1 de 1
    • Remove the motherboard.
Marcus Elysee
Membre depuis le 10/25/19
97 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G8, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G8
3 membres
4 tutoriels rédigés
Un commentaire
Where can I buy this motherboard?
waymond everett - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 12
Total : 1,370
