Aller au contenu principal
RCA 22” DECK215R HDTV Button Replacement
Ce dont vous avez besoin
  1. RCA 22” DECK215R HDTV Button Replacement, Removing the Stand: étape 1, image 1 de 2 RCA 22” DECK215R HDTV Button Replacement, Removing the Stand: étape 1, image 2 de 2
    • Before disassembling your television, ensure that all cables are unplugged from their power source to avoid serious injury or death from electrocution.
    • Lay the TV flat with the screen facing down.
    • Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
    • Remove the stand by lifting it away from the TV's backing.
  2. RCA 22” DECK215R HDTV Button Replacement, Removing the Back Panel: étape 2, image 1 de 2 RCA 22” DECK215R HDTV Button Replacement, Removing the Back Panel: étape 2, image 2 de 2
    • Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
    • Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
    • While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
  3. RCA 22” DECK215R HDTV Button Replacement, Locate Pin: étape 3, image 1 de 1
    • Position the television to where the back panel is resting on the table and the screen is vertical.
    • Peel the tape covering the ribbon cable horizontally.
  4. RCA 22” DECK215R HDTV Button Replacement: étape 4, image 1 de 3 RCA 22” DECK215R HDTV Button Replacement: étape 4, image 2 de 3 RCA 22” DECK215R HDTV Button Replacement: étape 4, image 3 de 3
    • Pinch the clamps on both sides of the ribbon cable casing to detach it from the screen panel.
    • Remove the screen to isolate the back panel.
  5. RCA 22” DECK215R HDTV Button Replacement, Button: étape 5, image 1 de 2 RCA 22” DECK215R HDTV Button Replacement, Button: étape 5, image 2 de 2
    • Locate the button circuit board on top of the TV plastic frame.
    • Remove the blue and white ribbon cable connected to the circuit board by pulling with moderate to heavy force away from the circuit board.
  6. RCA 22” DECK215R HDTV Button Replacement, Locating the Top Buttons: étape 6, image 1 de 1
    • Remove the two 10mm Phillips #2 screws from the top of the button circuit board.
  7. RCA 22” DECK215R HDTV Button Replacement: étape 7, image 1 de 2 RCA 22” DECK215R HDTV Button Replacement: étape 7, image 2 de 2
    • Lightly peel back the TV's plastic frame, pressing down on the buttons from the outside.
    • Holding this position, insert a plastic opening tool on top of the button circuit board.
    • Apply forward pressure to pry out the circuit board and buttons from the frame.
Patrick Soper
Membre depuis le 01/15/15
691 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 70-2, Forte Winter 2015 Membre de l'équipe Cal Poly, Team 70-2, Forte Winter 2015
CPSU-FORTE-W15S70G2
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 11
Total : 641
