Aller au contenu principal
RCA CC310 Main Motherboard Replacement
Ce dont vous avez besoin
  1. RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: étape 1, image 1 de 2 RCA CC310 Main Motherboard Replacement, Disassembling RCA CC310 Left Cover: étape 1, image 2 de 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Main Motherboard Replacement: étape 2, image 1 de 2 RCA CC310 Main Motherboard Replacement: étape 2, image 2 de 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Main Motherboard Replacement: étape 3, image 1 de 2 RCA CC310 Main Motherboard Replacement: étape 3, image 2 de 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Main Motherboard Replacement: étape 4, image 1 de 2 RCA CC310 Main Motherboard Replacement: étape 4, image 2 de 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Main Motherboard Replacement, Main Motherboard: étape 5, image 1 de 2 RCA CC310 Main Motherboard Replacement, Main Motherboard: étape 5, image 2 de 2
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
  6. RCA CC310 Main Motherboard Replacement: étape 6, image 1 de 2 RCA CC310 Main Motherboard Replacement: étape 6, image 2 de 2
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
  7. RCA CC310 Main Motherboard Replacement: étape 7, image 1 de 1
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
Oliver Adams
Membre depuis le 01/19/11
629 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 5-20, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 21
Total : 2,714
