Aller au contenu principal
RCA CC310 Onboard Microphone Replacement
Ce dont vous avez besoin
  1. RCA CC310 Onboard Microphone Replacement, Onboard Microphone: étape 1, image 1 de 2 RCA CC310 Onboard Microphone Replacement, Onboard Microphone: étape 1, image 2 de 2
    • Lift the metal flap and slide the viewfinder off to the right.
  2. RCA CC310 Onboard Microphone Replacement: étape 2, image 1 de 3 RCA CC310 Onboard Microphone Replacement: étape 2, image 2 de 3 RCA CC310 Onboard Microphone Replacement: étape 2, image 3 de 3
    • Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable is connected to the viewfinder.
    • Disconnect the cable inside by pulling it apart.
  3. RCA CC310 Onboard Microphone Replacement: étape 3, image 1 de 2 RCA CC310 Onboard Microphone Replacement: étape 3, image 2 de 2
    • Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up.
  4. RCA CC310 Onboard Microphone Replacement: étape 4, image 1 de 2 RCA CC310 Onboard Microphone Replacement: étape 4, image 2 de 2
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  5. RCA CC310 Onboard Microphone Replacement: étape 5, image 1 de 1
    • Turn the microphone circuit board over.
    • Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
  6. RCA CC310 Onboard Microphone Replacement: étape 6, image 1 de 1
    • Desolder the metal protective housing using a soldering iron.
    • Desolder the microphone and replace it.
Oliver Adams
Membre depuis le 01/19/11
629 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 5-20, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 912
