Aller au contenu principal
Introduction
This guide will instruct you to replace the onboard microphone if it is faulty.
  1. Lift the metal flap and slide  the viewfinder off to the right. Lift the metal flap and slide  the viewfinder off to the right.
    • Lift the metal flap and slide the viewfinder off to the right.
  2. Unscrew the 7.0mm ph#0 screw on the underside where the cable connects. Lift the plastic where the cable is connected to the viewfinder. Disconnect the cable inside by pulling it apart.
    • Unscrew the 7.0mm ph#0 screw on the underside where the cable connects.
    • Lift the plastic where the cable is connected to the viewfinder.
    • Disconnect the cable inside by pulling it apart.
  3. Ignorez les nouveaux gadgets.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    SKIPANDSAVE10
    Save Now
  4. Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly. Lift the viewfinder plastic assembly up.
    • Unscrew the two 7mm ph#0 screws on the underside of the viewfinder assembly.
    • Lift the viewfinder plastic assembly up.
  5. Lift the microphone circuit board straight up. Unclip the cable connected to the circuit board.
    • Lift the microphone circuit board straight up.
    • Unclip the cable connected to the circuit board.
  6. Turn the microphone circuit board over.
    • Turn the microphone circuit board over.
    • Unscrew the two Ph#0 screws holding the plastic housing on the circuit board.
  7. Desolder the metal protective housing using a soldering iron.
    • Desolder the metal protective housing using a soldering iron.
    • Desolder the microphone and replace it.
Oliver Adams
Membre depuis le 19/01/2011
620 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 5-20, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 712
