Aller au contenu principal
RCA CC310 Onboard Speaker Replacement
Ce dont vous avez besoin
  1. RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: étape 1, image 1 de 2 RCA CC310 Onboard Speaker Replacement, Disassembling RCA CC310 Left Cover: étape 1, image 2 de 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. RCA CC310 Onboard Speaker Replacement: étape 2, image 1 de 2 RCA CC310 Onboard Speaker Replacement: étape 2, image 2 de 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. RCA CC310 Onboard Speaker Replacement: étape 3, image 1 de 2 RCA CC310 Onboard Speaker Replacement: étape 3, image 2 de 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. RCA CC310 Onboard Speaker Replacement: étape 4, image 1 de 2 RCA CC310 Onboard Speaker Replacement: étape 4, image 2 de 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  5. RCA CC310 Onboard Speaker Replacement, Onboard Speaker: étape 5, image 1 de 2 RCA CC310 Onboard Speaker Replacement, Onboard Speaker: étape 5, image 2 de 2
    • Unplug the red cable connecting the speaker to the motherboard.
  6. RCA CC310 Onboard Speaker Replacement: étape 6, image 1 de 2 RCA CC310 Onboard Speaker Replacement: étape 6, image 2 de 2
    • Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
    • Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
  7. RCA CC310 Onboard Speaker Replacement: étape 7, image 1 de 1
    • Break the plastic pieces holding the cable to the panel.
    • Glue the new cables, with a hot glue gun, back to the panel after replacing the speaker.
  8. RCA CC310 Onboard Speaker Replacement: étape 8, image 1 de 3 RCA CC310 Onboard Speaker Replacement: étape 8, image 2 de 3 RCA CC310 Onboard Speaker Replacement: étape 8, image 3 de 3
    • Glue the new speaker to the panel.
    • Plug the cable back into the motherboard.
Oliver Adams
Membre depuis le 01/19/11
629 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 5-20, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 995
