Aller au contenu principal
RCA Lyra X2400 Motherboard Replacement
Ce dont vous avez besoin
  1. RCA Lyra X2400 Motherboard Replacement, Battery: étape 1, image 1 de 3 RCA Lyra X2400 Motherboard Replacement, Battery: étape 1, image 2 de 3 RCA Lyra X2400 Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Using slight pressure with your finger on the word "OPEN", slide the battery plate down.
    • Remove the battery plate.
    • Place your finger at the bottom of the battery.
    • Lift up on the battery until it pops out from the LYRA X2400.
  2. RCA Lyra X2400 Motherboard Replacement, Screen: étape 2, image 1 de 2 RCA Lyra X2400 Motherboard Replacement, Screen: étape 2, image 2 de 2
    • Remove the two Phillips screws from the silver cover at the top of the Lyra.
    • Slowly wiggle the silver cover while pulling it away from the device.
  3. RCA Lyra X2400 Motherboard Replacement: étape 3, image 1 de 2 RCA Lyra X2400 Motherboard Replacement: étape 3, image 2 de 2
    • Remove the two Phillips screws from the bottom of the device, next to the charger port and Compact Flash release button.
    • Pull the silver case from the bottom of the device.
  4. RCA Lyra X2400 Motherboard Replacement: étape 4, image 1 de 3 RCA Lyra X2400 Motherboard Replacement: étape 4, image 2 de 3 RCA Lyra X2400 Motherboard Replacement: étape 4, image 3 de 3
    • Carefully pry up the screen with a plastic opening tool.
    • Disconnect the screen's ribbon cable from the circuit board.
    • Remove the screen.
  5. RCA Lyra X2400 Motherboard Replacement, Motherboard: étape 5, image 1 de 2 RCA Lyra X2400 Motherboard Replacement, Motherboard: étape 5, image 2 de 2
    • Open the case of the Lyra.
    • Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
Evan Lindquist
Membre depuis le 04/11/13
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-3, Regan Spring 2013 Membre de l'équipe Cal Poly, Team 17-3, Regan Spring 2013
CPSU-REGAN-S13S17G3
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 341
