Introduction
Use this guide to replace the USB port of the RCA Lyra X2400.
Ce dont vous avez besoin
Remove the two Phillips screws from the silver cover at the top of the Lyra.
Slowly wiggle the silver cover while pulling it away from the device.
Open the case of the Lyra.
Remove the four screws that secure the motherboard to the frame of the Lyra X2400.
Locate the USB in/out component on your Lyra X2400. If you are having difficulty locating this component the picture to the left will show you where it is located.
Start using solder/desolder tools to remove the USB in/out.
Once removed replace it with the new working USB in/out.
Use the soldering tools to reattach the component back to the main logic board.
