Aller au contenu principal
RCA RCR8622 LCD Screen Replacement
Ce dont vous avez besoin
  1. RCA RCR8622 LCD Screen Replacement, Speaker: étape 1, image 1 de 3 RCA RCR8622 LCD Screen Replacement, Speaker: étape 1, image 2 de 3 RCA RCR8622 LCD Screen Replacement, Speaker: étape 1, image 3 de 3
    • Remove the casing. Slide the plastic cover with the graphic off the main base. Be careful and hold both sides.
    • Flip the device over and unscrew the five 11 mm screws with a Phillip's #1 screwdriver.
    • A magnetic screwdriver will help you remove the screws from their slots.
  2. RCA RCR8622 LCD Screen Replacement: étape 2, image 1 de 3 RCA RCR8622 LCD Screen Replacement: étape 2, image 2 de 3 RCA RCR8622 LCD Screen Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    • Pull the top of the device off and look closely at the motherboard. You will see two speakers, one on each side of the device.
    • Grab the tweezers and follow the red and black wires leading from the speaker to the motherboard. They will attach to a white casing. Lift the white plug out with the tweezers to disconnect.
  3. RCA RCR8622 LCD Screen Replacement: étape 3, image 1 de 2 RCA RCR8622 LCD Screen Replacement: étape 3, image 2 de 2
    • Grab the speaker and pull upward. The Speakers will be loose.
    • Repeat this step with the other speaker.
  4. RCA RCR8622 LCD Screen Replacement, LCD Screen: étape 4, image 1 de 3 RCA RCR8622 LCD Screen Replacement, LCD Screen: étape 4, image 2 de 3 RCA RCR8622 LCD Screen Replacement, LCD Screen: étape 4, image 3 de 3
    • Remove the two 11mm screws from the motherboard with the Phillip's #1 screwdriver.
    • Squeeze the 2 metal prongs on the interior of the motherboard inward until a clicking noise is heard.
  5. RCA RCR8622 LCD Screen Replacement: étape 5, image 1 de 3 RCA RCR8622 LCD Screen Replacement: étape 5, image 2 de 3 RCA RCR8622 LCD Screen Replacement: étape 5, image 3 de 3
    • Lift the motherboard out of the interior of the device.
    • Remove the screen section of the device by lifting upward on the circuit it is connected to by sliding it upwards.
    • Both sections will be connected with a ribbon connection.
  6. RCA RCR8622 LCD Screen Replacement: étape 6, image 1 de 3 RCA RCR8622 LCD Screen Replacement: étape 6, image 2 de 3 RCA RCR8622 LCD Screen Replacement: étape 6, image 3 de 3
    • Flip both components of the circuitry over and from the main motherboard you will see metal pins that lead to the LCD screen.
    • Heat the solder around the pins with a soldering iron so the pins can be removed and the screen can be detached. Use a flat object to help push out the pins.
  7. RCA RCR8622 LCD Screen Replacement: étape 7, image 1 de 2 RCA RCR8622 LCD Screen Replacement: étape 7, image 2 de 2
    • Lift the screen upward, taking care not to allow the films below it to fall out.
Josh Excell
Membre depuis le 03/20/18
449 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S6-G5, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S6-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G5
3 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 12
Total : 313
