Aller au contenu principal
RCA RCT6077W2 Camera Replacement
Ce dont vous avez besoin
  1. RCA RCT6077W2 Camera Replacement, Backplate: étape 1, image 1 de 2 RCA RCT6077W2 Camera Replacement, Backplate: étape 1, image 2 de 2
    • Remove the two 2.5mm Phillips head screws before attempting to remove the screen from the device.
  2. RCA RCT6077W2 Camera Replacement: étape 2, image 1 de 2 RCA RCT6077W2 Camera Replacement: étape 2, image 2 de 2
    • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
    • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
    • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
  3. RCA RCT6077W2 Camera Replacement, Camera: étape 3, image 1 de 1
    • The camera is located in the corner of the motherboard, attached by a ribbon cable. Lift up on the black latch that is holding in the ribbon cable and the cable should pop up and out.
    • Do not use force to try to remove the ribbon cable. The latch may not be lifted up completely, and force can break the ribbon cable away from its connector.
  4. RCA RCT6077W2 Camera Replacement: étape 4, image 1 de 1
    • Once the cable is removed from the motherboard, the entire camera can simply be removed from the device.
2 autres ont terminé cette réparation.
Ryan Williams
Membre depuis le 01/27/15
1 157 Réputation
4 tutoriels rédigés
Équipe
Pasco Hernando, Team 1-2, Prince Winter 2015 Membre de l'équipe Pasco Hernando, Team 1-2, Prince Winter 2015
PHSC-PRINCE-W15S1G2
6 membres
8 tutoriels rédigés
Un commentaire
Where can I get the replacement parts (camera and flex cable)
tuesday cannon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 978
