Aller au contenu principal
RCA RCT6303W87 Speaker Replacement
Ce dont vous avez besoin
  1. RCA RCT6303W87 Speaker Replacement, Battery: étape 1, image 1 de 3 RCA RCT6303W87 Speaker Replacement, Battery: étape 1, image 2 de 3 RCA RCT6303W87 Speaker Replacement, Battery: étape 1, image 3 de 3
    • Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
  2. RCA RCT6303W87 Speaker Replacement: étape 2, image 1 de 1
    • Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
  3. RCA RCT6303W87 Speaker Replacement: étape 3, image 1 de 3 RCA RCT6303W87 Speaker Replacement: étape 3, image 2 de 3 RCA RCT6303W87 Speaker Replacement: étape 3, image 3 de 3
    • Remove cover completely.
  4. RCA RCT6303W87 Speaker Replacement: étape 4, image 1 de 3 RCA RCT6303W87 Speaker Replacement: étape 4, image 2 de 3 RCA RCT6303W87 Speaker Replacement: étape 4, image 3 de 3
    • Disconnect battery cable from the motherboard.
  5. RCA RCT6303W87 Speaker Replacement: étape 5, image 1 de 3 RCA RCT6303W87 Speaker Replacement: étape 5, image 2 de 3 RCA RCT6303W87 Speaker Replacement: étape 5, image 3 de 3
    • Pull the thin black keyboard connector off and set it aside.
  6. RCA RCT6303W87 Speaker Replacement: étape 6, image 1 de 3 RCA RCT6303W87 Speaker Replacement: étape 6, image 2 de 3 RCA RCT6303W87 Speaker Replacement: étape 6, image 3 de 3
    • Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
  7. RCA RCT6303W87 Speaker Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Use nylon spudger tool or plastic card to separate battery from the case.
  8. RCA RCT6303W87 Speaker Replacement: étape 8, image 1 de 3 RCA RCT6303W87 Speaker Replacement: étape 8, image 2 de 3 RCA RCT6303W87 Speaker Replacement: étape 8, image 3 de 3
    • Carefully peel off the battery.
  9. RCA RCT6303W87 Speaker Replacement, Speaker: étape 9, image 1 de 3 RCA RCT6303W87 Speaker Replacement, Speaker: étape 9, image 2 de 3 RCA RCT6303W87 Speaker Replacement, Speaker: étape 9, image 3 de 3
    • Disconnect the speaker cord from the motherboard.
  10. RCA RCT6303W87 Speaker Replacement: étape 10, image 1 de 3 RCA RCT6303W87 Speaker Replacement: étape 10, image 2 de 3 RCA RCT6303W87 Speaker Replacement: étape 10, image 3 de 3
    • Use the plastic spudger to slide the speaker out.
Akitaka Hashimoto
Membre depuis le 03/27/18
525 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G2, Harley Spring 2018 Membre de l'équipe IUPUI, Team S3-G2, Harley Spring 2018
IUPUI-HARLEY-S18S3G2
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 442
