Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Archivé
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Archivé
Introduction
If the screen of the device becomes cracked or stops registering touch commands, use the following guide to replace the screen.
  1. Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
    • Remove two 2.4mm x 4mm screws from bottom of the tablet with Phillips #00 Screwdriver.
  2. Remove back cover with lever tool, exposing the battery and motherboard. Remove back cover with lever tool, exposing the battery and motherboard.
    • Remove back cover with lever tool, exposing the battery and motherboard.
  3. Le kit d'outils Essentiel
    Les outils les plus utiles dans notre kit le plus compact.
    J'achète
    J'achète
  4. Using the tweezers, remove the black tape connecting the screen to the motherboard. Using the tweezers, remove the black tape connecting the screen to the motherboard.
    • Using the tweezers, remove the black tape connecting the screen to the motherboard.
  5. Pull up the switch to remove the input connector. Pull up the switch to remove the input connector.
    • Pull up the switch to remove the input connector.
  6. Heat the iOpener in the microwave, following the instructions provided with the tool. Lay the heated iOpener on the front screen for two minutes to soften the connection of the screen to the tablet.
    • Heat the iOpener in the microwave, following the instructions provided with the tool. Lay the heated iOpener on the front screen for two minutes to soften the connection of the screen to the tablet.
  7. Use the suction cup and lever tool tool to pry the front screen from the tablet. Use the suction cup and lever tool tool to pry the front screen from the tablet.
    • Use the suction cup and lever tool tool to pry the front screen from the tablet.
2 autre(s) ont terminé cette réparation.
mikayla
Membre depuis le 29/01/2015
408 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 14-4, Shirley Spring 2015 Membre de l'équipe Clemson, Team 14-4, Shirley Spring 2015
CLEM-SHIRLEY-S15S14G4
6 membres
15 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,188
