Aller au contenu principal
RCA RCT6773W22 Battery Replacement
Ce dont vous avez besoin
  1. RCA RCT6773W22 Battery Replacement, Battery: étape 1, image 1 de 2 RCA RCT6773W22 Battery Replacement, Battery: étape 1, image 2 de 2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Battery Replacement: étape 2, image 1 de 3 RCA RCT6773W22 Battery Replacement: étape 2, image 2 de 3 RCA RCT6773W22 Battery Replacement: étape 2, image 3 de 3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Battery Replacement: étape 3, image 1 de 3 RCA RCT6773W22 Battery Replacement: étape 3, image 2 de 3 RCA RCT6773W22 Battery Replacement: étape 3, image 3 de 3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
2 autres ont terminé cette réparation.
Kelsea Weber
Membre depuis le 11/12/15
20 047 Réputation
32 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 077 tutoriels rédigés
Un commentaire
Umm, which battery do you need for it? Seems that’s a part that is kind of important.
Cathy Hajo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 3,873
