Aller au contenu principal
RCA RCT6773W22 Motherboard Replacement
Ce dont vous avez besoin
  1. RCA RCT6773W22 Motherboard Replacement, Battery: étape 1, image 1 de 2 RCA RCT6773W22 Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
  2. RCA RCT6773W22 Motherboard Replacement: étape 2, image 1 de 3 RCA RCT6773W22 Motherboard Replacement: étape 2, image 2 de 3 RCA RCT6773W22 Motherboard Replacement: étape 2, image 3 de 3
    • Place the plastic opening tool between the case and the screen.
    • Slide the tool clockwise around the case until all the clips are removed.
    • Do not completely separate the case from the screen because there is a wire connecting the motherboard to the speaker.
  3. RCA RCT6773W22 Motherboard Replacement: étape 3, image 1 de 3 RCA RCT6773W22 Motherboard Replacement: étape 3, image 2 de 3 RCA RCT6773W22 Motherboard Replacement: étape 3, image 3 de 3
    • Desolder the two wires that connect the battery to the motherboard.
    • Learn more about soldering with this soldering technique guide.
    • Using the blue plastic opening tool, lift the battery away from the device.
  4. RCA RCT6773W22 Motherboard Replacement, Speaker: étape 4, image 1 de 3 RCA RCT6773W22 Motherboard Replacement, Speaker: étape 4, image 2 de 3 RCA RCT6773W22 Motherboard Replacement, Speaker: étape 4, image 3 de 3
    • Desolder the wire connected from the speaker to the motherboard.
    • Pry the speaker from the casing with a plastic opening tool.
  5. RCA RCT6773W22 Motherboard Replacement, Motherboard: étape 5, image 1 de 3 RCA RCT6773W22 Motherboard Replacement, Motherboard: étape 5, image 2 de 3 RCA RCT6773W22 Motherboard Replacement, Motherboard: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use the spudger to lift up the black tab on all three ZIF connectors.
    • Use tweezers to remove the ribbon cables from the zift connectors.
  6. RCA RCT6773W22 Motherboard Replacement: étape 6, image 1 de 1
    • Use Phillips #000 screwdriver to remove the three 3mm screws on the motherboard.
  7. RCA RCT6773W22 Motherboard Replacement: étape 7, image 1 de 2 RCA RCT6773W22 Motherboard Replacement: étape 7, image 2 de 2
    • Use a spudger or plastic opening tool to lift up the motherboard.
6 autres ont terminé cette réparation.
Kelsea Weber
Membre depuis le 11/12/15
20 047 Réputation
32 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 077 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 3,033
