Aller au contenu principal
RCA RP3715A Speaker Replacement
Ce dont vous avez besoin
  1. RCA RP3715A Speaker Replacement, Reaching the battery terminal.: étape 1, image 1 de 2 RCA RP3715A Speaker Replacement, Reaching the battery terminal.: étape 1, image 2 de 2
    • Push down on the clip to release pressure. The pull off the plastic cover.
  2. RCA RP3715A Speaker Replacement, Replacing the battery: étape 2, image 1 de 1
    • Remove the 9-volt battery from the battery terminal.
  3. RCA RP3715A Speaker Replacement, Getting inside the device.: étape 3, image 1 de 1
    • Take out the six screws located on the back of the device.
    • The red screws are 10 mm Phillip's #1. The orange screws are 13 mm Phillips #1.
    • Three screws are located on the back panel. One is located inside the battery carriage.
    • Two screws are located on the on the back panel on the bottom left and right side.
  4. RCA RP3715A Speaker Replacement, Relieve extension cord tension.: étape 4, image 1 de 3 RCA RP3715A Speaker Replacement, Relieve extension cord tension.: étape 4, image 2 de 3 RCA RP3715A Speaker Replacement, Relieve extension cord tension.: étape 4, image 3 de 3
    • Remove the 10 mm Phillip's #1 screw.
    • Then remove the metal reinforcement.
  5. RCA RP3715A Speaker Replacement: étape 5, image 1 de 2 RCA RP3715A Speaker Replacement: étape 5, image 2 de 2
    • Using flathead screwdriver undo the release tabs.
  6. RCA RP3715A Speaker Replacement: étape 6, image 1 de 3 RCA RP3715A Speaker Replacement: étape 6, image 2 de 3 RCA RP3715A Speaker Replacement: étape 6, image 3 de 3
    • Pry the release tabs with a spudger.
    • Start with back of the device on the topside.
  7. RCA RP3715A Speaker Replacement: étape 7, image 1 de 2 RCA RP3715A Speaker Replacement: étape 7, image 2 de 2
    • Pry open both tabs to remove the topside of the clock.
  8. RCA RP3715A Speaker Replacement, Speaker Replacement: étape 8, image 1 de 1
    • Remove the two 10mm Phillip's #1 screws. Also remove the two reinforcements holding the speaker in place.
Myles Waiters
Membre depuis le 09/22/14
370 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 10-5, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-5, Brown Fall 2014
USFT-BROWN-F14S10G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 13
Total : 222
