Aller au contenu principal
RIDGID R2740 Ball Bearing Replacement
Ce dont vous avez besoin
  1. RIDGID R2740 Ball Bearing Replacement, Ball Bearing: étape 1, image 1 de 2 RIDGID R2740 Ball Bearing Replacement, Ball Bearing: étape 1, image 2 de 2
    • Orient the belt sander so that the AirGuard Technology logo is facing you.
    • Remove the nine 19mm, two 51mm and one 32 mm screws that hold the cover into place.
    • Remove the cover from the belt sander.
    • Make sure you remember the correct placement of each screw.
  2. RIDGID R2740 Ball Bearing Replacement: étape 2, image 1 de 1
    • Remove the assembly armature from the belt sander.
    • You may need to wiggle the assembly armature to remove it from the belt sander.
  3. RIDGID R2740 Ball Bearing Replacement: étape 3, image 1 de 2 RIDGID R2740 Ball Bearing Replacement: étape 3, image 2 de 2
    • Use a hammer to pry the ball bearing from the assembly armature.
    • The ball bearing can be somewhat difficult to remove. You may need to apply WD-40 before removal.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 1,020
