Aller au contenu principal
RIDGID R2740 Motherboard Replacement
Ce dont vous avez besoin
  1. RIDGID R2740 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Unplug your device before proceeding..
  2. RIDGID R2740 Motherboard Replacement: étape 2, image 1 de 1
    • Orient the sander so the Air Guard logo is facing you.
    • Remove the single Torx TR20 screw.
  3. RIDGID R2740 Motherboard Replacement: étape 3, image 1 de 2 RIDGID R2740 Motherboard Replacement: étape 3, image 2 de 2
    • Orient the device with the left side face up.
    • Using a Phillips #1 bit, unscrew the 3 screws which hold the internal casing in place.
    • Gently remove the belt.
    • Using the Torx TR10 bit, unscrew the 10 screws which hold the external casing in place.
  4. RIDGID R2740 Motherboard Replacement: étape 4, image 1 de 1
    • Gently pull up on the motherboard chip set, pulling it directly from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 18
Total : 608
