Aller au contenu principal
RIDGID R2740 Motor Replacement
Ce dont vous avez besoin
  1. RIDGID R2740 Motor Replacement, Motor: étape 1, image 1 de 1
    • Orient the Ridgid Sander to where the Air Guard logo is facing upwards.
    • Unscrew the outlined screw in the figure with a Torx TR10 screw bit.
    • Remove the guard that is protecting the tread-line.
  2. RIDGID R2740 Motor Replacement: étape 2, image 1 de 3 RIDGID R2740 Motor Replacement: étape 2, image 2 de 3 RIDGID R2740 Motor Replacement: étape 2, image 3 de 3
    • See attached diagram.
    • The guard below the wheels should be able to lift up out of place.
    • Remove the timing belt from the pulleys.
    • Unscrew the three screws with a Phillips #1 screwdriver.
    • Remove the large pulley after removing the screw.
    • Using the Torx TR10 Bit, unscrew the 10 screws which hold the external casing in place.
  3. RIDGID R2740 Motor Replacement: étape 3, image 1 de 1
    • Remove the plastic housing by lifting it up from the device.
  4. RIDGID R2740 Motor Replacement: étape 4, image 1 de 1
    • Flip the Ridgid Sander so that the Ridgid logo faces upwards.
    • The Ridgid Logo should be facing upwards.
  5. RIDGID R2740 Motor Replacement: étape 5, image 1 de 3 RIDGID R2740 Motor Replacement: étape 5, image 2 de 3 RIDGID R2740 Motor Replacement: étape 5, image 3 de 3
    • Remove the brush caps from either side using a flathead screwdriver (See attached diagram).
    • Remove the plastic cover with the Ridgid logo.
    • Remove the brush assembly (See attached diagram).
  6. RIDGID R2740 Motor Replacement: étape 6, image 1 de 2 RIDGID R2740 Motor Replacement: étape 6, image 2 de 2
    • Now orient the Rigid Sander to the other side that shows the exposed motor.
    • The motor will be able to lift up out of place.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 19
Total : 640
