Aller au contenu principal
RIDGID R32104 Motor Brush Replacement
Ce dont vous avez besoin
  1. RIDGID R32104 Motor Brush Replacement, Motor Brush: étape 1, image 1 de 2 RIDGID R32104 Motor Brush Replacement, Motor Brush: étape 1, image 2 de 2
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Brush Replacement: étape 2, image 1 de 2 RIDGID R32104 Motor Brush Replacement: étape 2, image 2 de 2
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Brush Replacement: étape 3, image 1 de 1
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
Lucas Pimentel
Membre depuis le 04/02/19
1 010 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Julie Spring 2019 Membre de l'équipe UMass Dartmouth, Team S5-G1, Julie Spring 2019
UMASSD-JULIE-S19S5G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 781
