Aller au contenu principal
RIDGID R32104 Motor Rotor Replacement
Ce dont vous avez besoin
  1. RIDGID R32104 Motor Rotor Replacement, Motor Brush: étape 1, image 1 de 2 RIDGID R32104 Motor Rotor Replacement, Motor Brush: étape 1, image 2 de 2
    • Turn off your saw and unplug before starting.
    • Place down the Worm Drive Saw on a sturdy surface.
    • The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
  2. RIDGID R32104 Motor Rotor Replacement: étape 2, image 1 de 2 RIDGID R32104 Motor Rotor Replacement: étape 2, image 2 de 2
    • Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
  3. RIDGID R32104 Motor Rotor Replacement: étape 3, image 1 de 1
    • With the cap removed, the motor brush should now be accessible.
    • Carefully remove the motor brush by sliding it out of the main housing assembly.
  4. RIDGID R32104 Motor Rotor Replacement, Upper Blade Guard Assembly: étape 4, image 1 de 3 RIDGID R32104 Motor Rotor Replacement, Upper Blade Guard Assembly: étape 4, image 2 de 3 RIDGID R32104 Motor Rotor Replacement, Upper Blade Guard Assembly: étape 4, image 3 de 3
    • Maneuver the RIDGID saw, in order to easily remove the upper blade guard assembly.
    • Using the T20 Torx Screwdriver, remove the four 4/10 cm screws that attach to the gear box.
  5. RIDGID R32104 Motor Rotor Replacement: étape 5, image 1 de 2 RIDGID R32104 Motor Rotor Replacement: étape 5, image 2 de 2
    • Using the T50 Torx Screwdriver, remove the one 5/10 screw that attach to the gear box.
  6. RIDGID R32104 Motor Rotor Replacement: étape 6, image 1 de 2 RIDGID R32104 Motor Rotor Replacement: étape 6, image 2 de 2
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach to the handle of the device.
  7. RIDGID R32104 Motor Rotor Replacement: étape 7, image 1 de 2 RIDGID R32104 Motor Rotor Replacement: étape 7, image 2 de 2
    • Maneuver the saw to get to the base plate.
    • Using the T20 Torx Screwdriver, remove the two 4/10 cm screws that attach the upper blade guard’s base plate to the main housing assembly.
  8. RIDGID R32104 Motor Rotor Replacement, Main Housing Assembly: étape 8, image 1 de 2 RIDGID R32104 Motor Rotor Replacement, Main Housing Assembly: étape 8, image 2 de 2
    • Using the T20 Torx Screwdriver, remove the four 10 cm screws that attaches the main housing assembly to the gear box.
  9. RIDGID R32104 Motor Rotor Replacement, Gear Box: étape 9, image 1 de 2 RIDGID R32104 Motor Rotor Replacement, Gear Box: étape 9, image 2 de 2
    • Wiggle out the gear box to easily gain access to the motor rotor.
    • Once taken out, the motor rotor is easily accessible.
  10. RIDGID R32104 Motor Rotor Replacement, Motor Rotor: étape 10, image 1 de 3 RIDGID R32104 Motor Rotor Replacement, Motor Rotor: étape 10, image 2 de 3 RIDGID R32104 Motor Rotor Replacement, Motor Rotor: étape 10, image 3 de 3
    • The motor rotor is lodged in between the armature and can be identified as a rod containing a fan blade.
    • Carefully remove the motor rotor from the device.
Lucas Pimentel
Membre depuis le 04/02/19
1 010 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Julie Spring 2019 Membre de l'équipe UMass Dartmouth, Team S5-G1, Julie Spring 2019
UMASSD-JULIE-S19S5G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 438
