Aller au contenu principal
RIDGID R32104 Saw Blade Replacement
Ce dont vous avez besoin
  1. RIDGID R32104 Saw Blade Replacement, Saw Blade: étape 1, image 1 de 1
    • Turn off your saw and unplug before starting.
    • The RIDGID R32104 Saw did not come with a blade, so paper was used to mime the actions needed.
    • Place the Worm Drive Saw on a sturdy surface.
    • The blade is located within its upper blade guard and lower swing guard assembly.
  2. RIDGID R32104 Saw Blade Replacement: étape 2, image 1 de 2 RIDGID R32104 Saw Blade Replacement: étape 2, image 2 de 2
    • Using a H-6 mm Allen Key, remove the 3/8 - 16 UNC LH screw, washer, and outer blade washer that fixes the blade in place.
    • In order to unscrew this, you must turn the screw clockwise to loosen it.
  3. RIDGID R32104 Saw Blade Replacement: étape 3, image 1 de 1
    • Adjust the lower swing guard to properly grab the blade.
  4. RIDGID R32104 Saw Blade Replacement: étape 4, image 1 de 1
    • Remove the blade by gingerly grabbing towards its center, preventing any injury from occurring.
Lucas Pimentel
Membre depuis le 04/02/19
1 010 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Julie Spring 2019 Membre de l'équipe UMass Dartmouth, Team S5-G1, Julie Spring 2019
UMASSD-JULIE-S19S5G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 24
Total : 1,102
