Introduction
If the blade on your Worn Drive Saw suddenly stops, makes improper cuts, or you experience kickback, the blade is faulty or is misaligned. Use this guide to remove or realign the blade. You just need a H-6 mm Allen Key, in order to remove one type of screw in the replacement process.
Ce dont vous avez besoin
Place the Worm Drive Saw on a sturdy surface.
The blade is located within its upper blade guard and lower swing guard assembly.
