Aller au contenu principal
RIDGID R84015 X2 Disassembly
Ce dont vous avez besoin
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: étape 1, image 1 de 2 RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: étape 1, image 2 de 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: étape 2, image 1 de 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: étape 3, image 1 de 2 RIDGID R84015 X2 Disassembly: étape 3, image 2 de 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: étape 4, image 1 de 1
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: étape 5, image 1 de 1
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: étape 6, image 1 de 1
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: étape 7, image 1 de 1
    • Make sure plastic is not broken and switch is not stuck.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Brian
Membre depuis le 04/12/10
97 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-48, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 membres
10 tutoriels rédigés
Un commentaire
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 21
Total : 13,546
