Aller au contenu principal
RIDGID R84015 X2 Planetary Gear Replacement Guide
Ce dont vous avez besoin
  1. RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: étape 1, image 1 de 2 RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: étape 1, image 2 de 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Planetary Gear Replacement Guide: étape 2, image 1 de 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Planetary Gear Replacement Guide: étape 3, image 1 de 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: étape 3, image 2 de 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Planetary Gear Replacement Guide, Planetary Gear: étape 4, image 1 de 1
    • Prepare to remove the gear chamber.
    • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
  5. RIDGID R84015 X2 Planetary Gear Replacement Guide: étape 5, image 1 de 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: étape 5, image 2 de 2
    • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
    • NOTE: Handle the gear chamber with caution as the gears are now loose.
  6. RIDGID R84015 X2 Planetary Gear Replacement Guide: étape 6, image 1 de 1
    • Remove the plastic gear chamber.
    • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
  7. RIDGID R84015 X2 Planetary Gear Replacement Guide: étape 7, image 1 de 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: étape 7, image 2 de 2
    • Remove each component from the gear assembly. Replace components as needed.
    • Reassemble the drill following the gear replacement instructions in reverse order.
Ligne d'arrivée
4 autres ont terminé cette réparation.
Evan Long
Membre depuis le 04/15/10
262 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 15-48, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 membres
10 tutoriels rédigés
Un commentaire
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 18
Total : 6,210
