Introduction
Extensive use or improper care of an RK61 mechanical keyboard can wear out the battery in no time. The keyboard will become unresponsive, but the battery can be replaced easily so you can continue using the keyboard. For this battery replacement guide, you will need a small screw driver and a new lithium-ion battery.
Ce dont vous avez besoin
2 autres ont terminé cette réparation.
10 commentaires
Is it possible to replace the standard battery with a larger one with no issues other then additional weight? say a 4000 mAh which will just be longer?
There should be no issues with replacing the keyboard with a larger battery as long as the connector is the same size and the battery is small enough so that you can still cover the PCB entirely with the keyboard case.
hey did u ever wind up doing the mod?
yo. ty for the guide.
i am also interested in upgrading the battery but am unsure about:
which dimensions the new battery should be, or how to find out
if it is safe to further modify the kb with additional material through the usual mods ppl to
should be fine to mod it to your liking
to measure simply measure the length breadth and max height u can have inside the cover and get a battery accordingly
