Aller au contenu principal
RYOBI AG454 Motor Replacement
Ce dont vous avez besoin
  1. RYOBI AG454 Motor Replacement, Rotator Handle: étape 1, image 1 de 1
    • Lay the handle on it's side, with the screws facing up.
  2. RYOBI AG454 Motor Replacement: étape 2, image 1 de 1
    • Remove the five 14mm screws from the rotating handle using the Phillips #1 screwdriver.
  3. RYOBI AG454 Motor Replacement: étape 3, image 1 de 1
    • Take the top part of the handle off.
  4. RYOBI AG454 Motor Replacement: étape 4, image 1 de 1
    • Unscrew the two 14mm screws from the clear bracket using the Phillips #1 screwdriver.
    • Remove the bracket.
  5. RYOBI AG454 Motor Replacement: étape 5, image 1 de 2 RYOBI AG454 Motor Replacement: étape 5, image 2 de 2
    • Push handle rotation latch and seperate the rest of the handle from main body.
  6. RYOBI AG454 Motor Replacement, Carbon Brush: étape 6, image 1 de 1
    • Remove the brush caps from each side of the body using the 4 mm flat head screwdriver.
  7. RYOBI AG454 Motor Replacement: étape 7, image 1 de 1
    • Remove the carbon brushes.
  8. RYOBI AG454 Motor Replacement, Driveshaft: étape 8, image 1 de 2 RYOBI AG454 Motor Replacement, Driveshaft: étape 8, image 2 de 2
    • Remove the two carbon brushes from both sides of the device.
  9. RYOBI AG454 Motor Replacement: étape 9, image 1 de 1
    • Remove the four 20mm screws that secures the gear box using a Phillips #1 screwdriver.
  10. RYOBI AG454 Motor Replacement: étape 10, image 1 de 1
    • Seperate the gear box case from body.
  11. RYOBI AG454 Motor Replacement: étape 11, image 1 de 1
    • Pull out drive shaft and remove it from the device.
  12. RYOBI AG454 Motor Replacement, Motor: étape 12, image 1 de 2 RYOBI AG454 Motor Replacement, Motor: étape 12, image 2 de 2
    • Remove the carbon brushes on both sides of the grinder.
  13. RYOBI AG454 Motor Replacement: étape 13, image 1 de 1
    • Remove the four 20mm screws securing gear box case using a Phillips #1 screwdriver.
  14. RYOBI AG454 Motor Replacement: étape 14, image 1 de 1
    • Seperate gear box case from body.
  15. RYOBI AG454 Motor Replacement: étape 15, image 1 de 1
    • Pull drive shaft from body of device.
  16. RYOBI AG454 Motor Replacement: étape 16, image 1 de 1
    • After removing the drive shaft pull out the cap.
  17. RYOBI AG454 Motor Replacement: étape 17, image 1 de 1
    • To remove the handle, remove the five screws using a Phillips #1 screwdriver.
  18. RYOBI AG454 Motor Replacement: étape 18, image 1 de 1
    • Cut the white wire that's located below the trigger in rear rotator handle with wire strippers.
    • When reassembling the handle twist the ends of the two wires together and crimp them.
  19. RYOBI AG454 Motor Replacement: étape 19, image 1 de 2 RYOBI AG454 Motor Replacement: étape 19, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the two screws from the bracket on the bottom of the body.
    • Remove the bracket from the device.
    • When reassembling be sure to pull the wires back through these two holes.
  20. RYOBI AG454 Motor Replacement: étape 20, image 1 de 1
    • Remove two screws from the motor using the Phillips #1 screwdriver.
  21. RYOBI AG454 Motor Replacement: étape 21, image 1 de 1
    • From the bottom of the body, slide the two coils off the brushes with a Jimmy.
    • When putting the coils back in place, use the Jimmy on top of the coils and push down the roll around the edges to push the coil down.
    • Another way of putting the coils back on is to push the Jimmy on top of coil and use another Jimmy to push down the back of the coil.
    • Putting on the coils may take multiple attempts so do not get frustrated if you can't get it on first try.
  22. RYOBI AG454 Motor Replacement: étape 22, image 1 de 1
    • Carefully pull motor along with wires straight out from the body and remove it from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 607
