Aller au contenu principal
RYOBI P422 Safety Trigger Spring Replacement
Ce dont vous avez besoin
  1. RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: étape 1, image 1 de 2 RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: étape 1, image 2 de 2
    • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
    • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
  2. RYOBI P422 Safety Trigger Spring Replacement, Safety Trigger Spring: étape 2, image 1 de 1
    • Lay grinder flat on its side so the screws are facing up
  3. RYOBI P422 Safety Trigger Spring Replacement: étape 3, image 1 de 3 RYOBI P422 Safety Trigger Spring Replacement: étape 3, image 2 de 3 RYOBI P422 Safety Trigger Spring Replacement: étape 3, image 3 de 3
    • Remove the four 1.8 cm screws from the lower and midsection of the body with a T20-20 Torque screwdriver.
    • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver
  4. RYOBI P422 Safety Trigger Spring Replacement: étape 4, image 1 de 3 RYOBI P422 Safety Trigger Spring Replacement: étape 4, image 2 de 3 RYOBI P422 Safety Trigger Spring Replacement: étape 4, image 3 de 3
    • Now that the two halves are unscrewed, remove the top half
  5. RYOBI P422 Safety Trigger Spring Replacement: étape 5, image 1 de 3 RYOBI P422 Safety Trigger Spring Replacement: étape 5, image 2 de 3 RYOBI P422 Safety Trigger Spring Replacement: étape 5, image 3 de 3
    • Remove the safety trigger along with the spring.
    • To remove the spring, pull it gently off the bottom of the trigger.
    • When putting a new spring in make sure it slides into the grove on the bottom of the trigger.
Thomas Napert
Membre depuis le 03/16/15
279 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-6, Duarte Spring 2015 Membre de l'équipe UMass Dartmouth, Team 3-6, Duarte Spring 2015
UMASSD-DUARTE-S15S3G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 9
Total : 1,530
