Aller au contenu principal
Rain-X Chipped Windshield Repair
Ce dont vous avez besoin
  1. Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: étape 1, image 1 de 3 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: étape 1, image 2 de 3 Rain-X Chipped Windshield Repair, Rain-X Chipped Windshield Repair: étape 1, image 3 de 3
    • To remove excess glass, scrape over the surface of the chip with the included razor blade.
  2. Rain-X Chipped Windshield Repair: étape 2, image 1 de 2 Rain-X Chipped Windshield Repair: étape 2, image 2 de 2
    • Attach the Rain-X applicator base to the windshield, with the center of the base directly above the chip.
  3. Rain-X Chipped Windshield Repair: étape 3, image 1 de 2 Rain-X Chipped Windshield Repair: étape 3, image 2 de 2
    • Cut the tip of the repair resin bottle using the razor blade.
  4. Rain-X Chipped Windshield Repair: étape 4, image 1 de 3 Rain-X Chipped Windshield Repair: étape 4, image 2 de 3 Rain-X Chipped Windshield Repair: étape 4, image 3 de 3
    • To attach resin chamber, screw the chamber into the center ring of the applicator base.
  5. Rain-X Chipped Windshield Repair: étape 5, image 1 de 1
    • Screw the resin chamber clockwise until it is in contact with the windshield.
  6. Rain-X Chipped Windshield Repair: étape 6, image 1 de 3 Rain-X Chipped Windshield Repair: étape 6, image 2 de 3 Rain-X Chipped Windshield Repair: étape 6, image 3 de 3
    • Apply 3-6 drops of resin from the resin repair bottle into the resin chamber.
  7. Rain-X Chipped Windshield Repair: étape 7, image 1 de 3 Rain-X Chipped Windshield Repair: étape 7, image 2 de 3 Rain-X Chipped Windshield Repair: étape 7, image 3 de 3
    • To add the pressure driver, screw the driver clockwise into the resin chamber.
    • Make sure to tighten almost all the way.
    • Make sure the pressure driver is in contact with the windshield.
  8. Rain-X Chipped Windshield Repair: étape 8, image 1 de 1
    • Set timer for 4-6 minutes - Let the adhesive absorb into the chip for 4-6 minutes.
    • To determine if the repair resin has absorbed properly, look at the glass from a 45 degree angle.
    • After the 4-6 minutes end, unscrew the pressure driver, turning it counter clockwise. Remove it to release any trapped air.
  9. Rain-X Chipped Windshield Repair: étape 9, image 1 de 2 Rain-X Chipped Windshield Repair: étape 9, image 2 de 2
    • Reinsert pressure driver by twisting clockwise.
    • This will discard any air remaining in the chip.
  10. Rain-X Chipped Windshield Repair: étape 10, image 1 de 1
    • To check for remaining damage, look for a dark color to appear.
  11. Rain-X Chipped Windshield Repair: étape 11, image 1 de 1
    • Leave to cure for 5-10 minutes.
  12. Rain-X Chipped Windshield Repair: étape 12, image 1 de 2 Rain-X Chipped Windshield Repair: étape 12, image 2 de 2
    • Once finished curing, remove the resin chamber and the pressure driver by screwing counter clockwise.
  13. Rain-X Chipped Windshield Repair: étape 13, image 1 de 2 Rain-X Chipped Windshield Repair: étape 13, image 2 de 2
    • Remove the applicator by using the tabs on the suction cups.
  14. Rain-X Chipped Windshield Repair: étape 14, image 1 de 2 Rain-X Chipped Windshield Repair: étape 14, image 2 de 2
    • Clean off any excess adhesive from the windshield.
  15. Rain-X Chipped Windshield Repair: étape 15, image 1 de 2 Rain-X Chipped Windshield Repair: étape 15, image 2 de 2
    • Cover the chip gently with a curing strip.
  16. Rain-X Chipped Windshield Repair: étape 16, image 1 de 1
    • Move the car into direct sunlight and leave for 4-6 hours.
    • Remove the curing strip and enjoy.
2 autres ont terminé cette réparation.
Jeffrey Ritchie
Membre depuis le 10/26/18
286 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S1-G8, Bender Fall 2018 Membre de l'équipe UC Davis, Team S1-G8, Bender Fall 2018
UCD-BENDER-F18S1G8
3 membres
1 tutoriel rédigé
Un commentaire
If you do not have a sunny day, what is the best UV wavelength in nm, watts, and length of time to fully cure the resin.
Thanks much!
AZRic - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 83
Total : 4,708
