Aller au contenu principal
Raleigh M20 Handlebars Replacement
Ce dont vous avez besoin
  1. Raleigh M20 Handlebars Replacement, Handlebars: étape 1, image 1 de 2 Raleigh M20 Handlebars Replacement, Handlebars: étape 1, image 2 de 2
    • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
    • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
  2. Raleigh M20 Handlebars Replacement: étape 2, image 1 de 3 Raleigh M20 Handlebars Replacement: étape 2, image 2 de 3 Raleigh M20 Handlebars Replacement: étape 2, image 3 de 3
    • Place an Allen wrench (size doesn't matter) under the bike grip.
    • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  3. Raleigh M20 Handlebars Replacement: étape 3, image 1 de 2 Raleigh M20 Handlebars Replacement: étape 3, image 2 de 2
    • Slide off the gear shifters.
    • Slide off the brake controls.
  4. Raleigh M20 Handlebars Replacement: étape 4, image 1 de 3 Raleigh M20 Handlebars Replacement: étape 4, image 2 de 3 Raleigh M20 Handlebars Replacement: étape 4, image 3 de 3
    • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
    • Lift the handlebars from the bike frame.
    • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
    • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Jon Ribera
Membre depuis le 09/26/12
72 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-49, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 21
Total : 2,117
