Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
This guide is designed to help Razer users replace the malfunctioning metal bar, located on the larger keys of their keyboard. The metal bar helps to provide tension, in order for the key to move up and down easily.
Pièces
Aucune pièce spécifiée.
  1. Before you do anything, take a picture of the entire keyboard so as to know where the keys go at the end.
    • Before you do anything, take a picture of the entire keyboard so as to know where the keys go at the end.
    • Gently start to remove the keys surrounding the keys with the bars in them.
  2. Move the key itself off of one side of the bar from where it connects to easily allow the other side to be removed as well. Another way to do it is to push the bar itself out gently with the metal spudger. Another way to do it is to push the bar itself out gently with the metal spudger.
    • Move the key itself off of one side of the bar from where it connects to easily allow the other side to be removed as well.
    • Another way to do it is to push the bar itself out gently with the metal spudger.
  3. Gently pop the bar out from its sockets. Pop the new bar back into the sockets.
    • Gently pop the bar out from its sockets.
    • Pop the new bar back into the sockets.
  4. Gently slide one side of the key into the bar and then use the metal spudger to pop the other side into place.
    • Gently slide one side of the key into the bar and then use the metal spudger to pop the other side into place.
    • Use the picture from the beginning if necessary to make sure all the keys are in the right place.
Haleigh Teegarden
Membre depuis le 17/01/2017
308 Réputation
3 tutoriels rédigés
Équipe
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 20
30 derniers jours : 81
Total : 1,471
