Introduction
Use this guide to remove or replace the back cover on your Razer Blade 15 Advanced Model (Early 2020) laptop.
Ce dont vous avez besoin
Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
Pull up on the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap.
Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
Remove the back cover.
Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
