Aller au contenu principal
Razer Blade 15 Motherboard Replacement
Ce dont vous avez besoin
  1. Razer Blade 15 Motherboard Replacement, Remove the Back Cover: étape 1, image 1 de 1
    • Flip over to the back side of the laptop
    • Remove the 10 screws at the bottom of the Razer using a T5 screwdriver head
  2. Razer Blade 15 Motherboard Replacement, Remove the Laptop Battery: étape 2, image 1 de 1
    • Unplug the battery and wear the anti-static band before proceeding
    • Unscrew the six Philips screws around the battery and lift the battery
  3. Razer Blade 15 Motherboard Replacement, Remove the SSD: étape 3, image 1 de 1
    • Find the SSD and unscrew the single screw
    • Once it is unscrewed, the SSD will pop up on one side
    • Carefully remove the SSD and place it to the side
  4. Razer Blade 15 Motherboard Replacement, Disconnect the MOBO Cables: étape 4, image 1 de 1
    • Locate the two display cables to the left of the left speaker and disconnect both. (one is underneath the other)
    • Locate and disconnect the four cables
    • Disconnect one cable that is underneath the SSD
    • Disconnect another cable that is next to the right fan
    • Disconnect the final two cables that are to the left of the battery connector
  5. Razer Blade 15 Motherboard Replacement, Remove the RAM and Wi-Fi Card: étape 5, image 1 de 1
    • Move the two metal pieces to each side and remove the two RAM
    • Disconnect the two thin cables connected to the Wi-Fi card
    • Remove the screw and carefully pull out the Wi-Fi card
  6. Razer Blade 15 Motherboard Replacement, Remove the Fans and Speakers: étape 6, image 1 de 1
    • Unscrew the four screws on the fans (two screws on each)
    • Make sure to unplug the connector on each of the fans. Lift and remove the fans.
    • Unscrew the four screws on the speakers (two screws on each)
    • Make sure to unplug the connector on each of the speakers and place them to the side
  7. Razer Blade 15 Motherboard Replacement, Remove the Motherboard and Hinges: étape 7, image 1 de 1
    • Remove the two screws on each hinge and pick up the black pieces
    • Locate the seven screws holding down the motherboard and remove them
    • Remove the plastic headphone jack cover
    • Lift up the MOBO and place it to the side
    • Be careful when handling the motherboard and make sure you’re wearing the anti-static band.
    • Make sure all of the cables are in sight once the motherboard has been placed down
    • Screw in both the motherboard screws and the hinges
    • Reconnect the motherboard connectors
    • Make sure you reconnect the Wi-Fi card and RAM
    • Place and screw in the fans and speakers
    • Make sure the SSD has been reconnected and screwed in
    • Screw the battery back in and reconnect the battery
    • Update DMI Info
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
4 autres ont terminé cette réparation.
Ved Pitre
Membre depuis le 10/30/19
1 092 Réputation
5 tutoriels rédigés
3 commentaires
does anyone know the size of the case screws
kody benard - Réponse
Anyone know the item number for a razer blade 15 2021 3060?
D Costa - Réponse
How to remove the vapor chamber? I'd like to repaste the GPU. I saw image of removed vapor chamber without removing much aside from battery.
With battery removed, display cable disconnected, screws of vapor chamber removed, it cannot be easily lift off, did i need to remove more? Or it's just old thermal paste sticking too much?
Patrick - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 40
30 derniers jours : 123
Total : 17,693
