Aller au contenu principal
Razer Blade 15" (2020) Back Cover Replacement
Ce dont vous avez besoin
  1. Razer Blade 15" (2020) Back Cover Replacement, Unfasten the back cover: étape 1, image 1 de 1
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  2. Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: étape 2, image 1 de 3 Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: étape 2, image 2 de 3 Razer Blade 15" (2020) Back Cover Replacement, Loosen the back cover: étape 2, image 3 de 3
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  3. Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: étape 3, image 1 de 3 Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: étape 3, image 2 de 3 Razer Blade 15" (2020) Back Cover Replacement, Remove the back cover: étape 3, image 3 de 3
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
Clay Eickemeyer
Membre depuis le 09/19/22
82 165 Réputation
455 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
9 membres
11 459 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 22
Total : 531
