Aller au contenu principal
Introduction
The purpose of heat pipes is to draw unwanted heat from the other components of the computer. You may want to remove the heat pipes if the computer is overheating to clean out the heat sinks on the end of the pipes. If the heat pipes are damaged and not working properly they should be replaced. The heat pipes are also required to be removed to work on some other components in this device.
Pièces
Aucune pièce spécifiée.
  1. Razer Blade RZ09-0102 Heat Pipe Replacement, Rear Panel: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop.
    • Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
    • Remove the back cover.
  2. Razer Blade RZ09-0102 Heat Pipe Replacement, Heat Pipes: étape 2, image 1 de 2 Razer Blade RZ09-0102 Heat Pipe Replacement, Heat Pipes: étape 2, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the six 8 mm screws holding the cooling rod to the motherboard .
  3. Razer Blade RZ09-0102 Heat Pipe Replacement: étape 3, image 1 de 1
    • Lift the cooling rod straight up and out of the laptop.
2 autres ont terminé cette réparation.
Kade Gonzalez
Membre depuis le 04/10/2018
121 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 1,072
