Aller au contenu principal
Razer Blade RZ09-0130 2015 Display Replacement
Ce dont vous avez besoin
  1. Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: étape 1, image 1 de 2 Razer Blade RZ09-0130 2015 Display Replacement, Back Panel: étape 1, image 2 de 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Display Replacement: étape 2, image 1 de 2 Razer Blade RZ09-0130 2015 Display Replacement: étape 2, image 2 de 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Display Replacement, Display: étape 3, image 1 de 1
    • Remove the two 5mm Phillips #00 screws.
  4. Razer Blade RZ09-0130 2015 Display Replacement: étape 4, image 1 de 1
    • Remove the plastic panel.
  5. Razer Blade RZ09-0130 2015 Display Replacement: étape 5, image 1 de 1
    • Remove one 3mm Phillips #00 screw from the metal plate.
  6. Razer Blade RZ09-0130 2015 Display Replacement: étape 6, image 1 de 1
    • Repeat the previous three steps on the opposing side.
  7. Razer Blade RZ09-0130 2015 Display Replacement: étape 7, image 1 de 1
    • Gently open the device with your hands and separate the display from the keyboard.
    • The device will make a popping or cracking sound when the two pieces separate. This is normal.
Ben Haering
Membre depuis le 01/29/20
121 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S18-G1, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 12
Total : 750
