Aller au contenu principal
Razer Blade RZ09-0130 2015 Speaker Replacement
Ce dont vous avez besoin
  1. Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: étape 1, image 1 de 2 Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: étape 1, image 2 de 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Speaker Replacement: étape 2, image 1 de 2 Razer Blade RZ09-0130 2015 Speaker Replacement: étape 2, image 2 de 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Speaker Replacement, Speaker: étape 3, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the two 3mm screws from the right speaker.
  4. Razer Blade RZ09-0130 2015 Speaker Replacement: étape 4, image 1 de 2 Razer Blade RZ09-0130 2015 Speaker Replacement: étape 4, image 2 de 2
    • Using your fingers, gently pull on the wire connecting the speaker to the motherboard until it disconnects.
  5. Razer Blade RZ09-0130 2015 Speaker Replacement: étape 5, image 1 de 1
    • Pick up and remove the speaker.
  6. Razer Blade RZ09-0130 2015 Speaker Replacement: étape 6, image 1 de 1
    • Repeat the preceding steps to remove the second speaker.
Carson Kellerman
Membre depuis le 01/29/20
495 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 348
