Aller au contenu principal
Razer Blade RZ09-0130 2015 Trackpad Button Replacement
Ce dont vous avez besoin
  1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: étape 1, image 1 de 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: étape 1, image 2 de 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: étape 2, image 1 de 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: étape 2, image 2 de 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: étape 3, image 1 de 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: étape 3, image 2 de 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: étape 3, image 3 de 3
    • Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
  4. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: étape 4, image 1 de 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: étape 4, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws holding the trackpad's circuit board to the chassis.
  5. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: étape 5, image 1 de 1
    • Remove the trackpad circuit board by holding one end and gently lifting it upwards.
Carson Kellerman
Membre depuis le 01/29/20
495 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 membres
6 tutoriels rédigés
Un commentaire
Looking for that small ribbon cable, very hard to find, any clues?
serpentexotics - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 2,148
