Aller au contenu principal
Razer Blade Stealth 2016 Hard Drive Replacement
Ce dont vous avez besoin
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Turn the laptop upside down!
  2. Razer Blade Stealth 2016 Hard Drive Replacement: étape 2, image 1 de 1
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
  3. Razer Blade Stealth 2016 Hard Drive Replacement: étape 3, image 1 de 1
    • The hard drive is located under the fan on the left side as shown in the picture!
  4. Razer Blade Stealth 2016 Hard Drive Replacement: étape 4, image 1 de 1
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
  5. Razer Blade Stealth 2016 Hard Drive Replacement: étape 5, image 1 de 2 Razer Blade Stealth 2016 Hard Drive Replacement: étape 5, image 2 de 2
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
  6. Razer Blade Stealth 2016 Hard Drive Replacement: étape 6, image 1 de 2 Razer Blade Stealth 2016 Hard Drive Replacement: étape 6, image 2 de 2
    • Carefully slide the hard drive out from its slot.
Lindsay Grant
Membre depuis le 10/10/19
403 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S1-G4, Leahy Fall 2019 Membre de l'équipe USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 45
Total : 2,799
