Aller au contenu principal
Razer Blade Stealth 2017 Audio and USB-A Port Replacement
Ce dont vous avez besoin
  1. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: étape 1, image 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: étape 1, image 2 de 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: étape 2, image 1 de 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: étape 3, image 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: étape 3, image 2 de 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: étape 5, image 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: étape 5, image 2 de 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: étape 6, image 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: étape 6, image 2 de 2
    • Use a plastic spudger to lift up the module connector.
  7. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: étape 7, image 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: étape 7, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and audio port module.
  8. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: étape 8, image 1 de 1
    • Use a plastic spudger to remove the USB-A and audio port module from the chassis.
Helene Willits
Membre depuis le 10/10/19
762 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S11-G3, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 15
Total : 1,715
