Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This is a prerequisite for all DeathAdder Chroma replacement guides.
Pièces
Aucune pièce spécifiée.
  1. Opening the mouse casing will void any  warranty that exists for the mouse.
    • Opening the mouse casing will void any warranty that exists for the mouse.
    • Turn the mouse over so the bottom is facing up.
  2. Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges. Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
    • Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
  3. Use a Phillips #0 screwdriver to remove two 6.7 mm screws. Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
    • Use a Phillips #0 screwdriver to remove two 6.7 mm screws.
  4. Use your fingers to identify the location of the screw under the bottom label.
    • Use your fingers to identify the location of the screw under the bottom label.
  5. Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Use a Phillips #0 screwdriver to remove one 6.7 mm screw.
    • Clear the label away from around the screw for easier removal.
  6. Turn the mouse over so the bottom is facing down. Separate the top casing from the bottom base by pulling the top casing upwards. Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
    • Turn the mouse over so the bottom is facing down.
    • Separate the top casing from the bottom base by pulling the top casing upwards.
    • Separating the casing too quickly could damage the ribbon connector between the motherboard and the LED lights.
  7. Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward. Pulling too hard could damage the wire connections.
    • Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
    • Pulling too hard could damage the wire connections.
Corrie Tung
Membre depuis le 24/03/2017
546 Réputation
2 tutoriels rédigés
Équipe
Baylor, Team S5-G2, Williams Spring 2017 Membre de l'équipe Baylor, Team S5-G2, Williams Spring 2017
BU-WILLIAMS-S17S5G2
3 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 55
