Aller au contenu principal
Razer Huntsman Tournament Edition Chassis Replacement
Ce dont vous avez besoin
  1. Razer Huntsman Tournament Edition Chassis Replacement, Keycaps: étape 1, image 1 de 1
    • Place the unplugged keyboard on a flat, clean surface appropriate for working on.
  2. Razer Huntsman Tournament Edition Chassis Replacement: étape 2, image 1 de 2 Razer Huntsman Tournament Edition Chassis Replacement: étape 2, image 2 de 2
    • Grip the keycap with your keycap puller.
    • You can remove keycaps with your fingers if you don’t have a puller, but the adjacent keycaps must be removed first for sufficient grip.
  3. Razer Huntsman Tournament Edition Chassis Replacement: étape 3, image 1 de 3 Razer Huntsman Tournament Edition Chassis Replacement: étape 3, image 2 de 3 Razer Huntsman Tournament Edition Chassis Replacement: étape 3, image 3 de 3
    • Pull with an upwards force to remove the keycap.
    • Take a moment to clean the area that was previously obscured if it’s dirty.
    • Use gentle force so as not to damage the stabilizers.
  4. Razer Huntsman Tournament Edition Chassis Replacement, Chassis: étape 4, image 1 de 1
    • Remove all of the keycaps with a keycap puller.
  5. Razer Huntsman Tournament Edition Chassis Replacement: étape 5, image 1 de 2 Razer Huntsman Tournament Edition Chassis Replacement: étape 5, image 2 de 2
    • Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
  6. Razer Huntsman Tournament Edition Chassis Replacement: étape 6, image 1 de 1
    • Use an opening tool to pry open the chassis.
    • Be careful not to use excessive force during this step so the plastic doesn't warp or break.
  7. Razer Huntsman Tournament Edition Chassis Replacement: étape 7, image 1 de 1
    • Gently lift the front panel off.
    • The front panel should be connected to the USB board. Do not tug the panel off as this may damage other parts.
  8. Razer Huntsman Tournament Edition Chassis Replacement: étape 8, image 1 de 1
    • Disconnect the internal cable.
Ben Altman
Membre depuis le 10/25/22
229 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-3, Sinclaire Fall 2022 Membre de l'équipe UMass Dartmouth, Team 4-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G3
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 24
Total : 474
